Hello,
On report I have Text control. I want write some text in this control. I wonder if is possible wrap text?
For example:
I want to write down text:
“Some text
continued text”
Regards.
AW
Hello,
For example:
“Some text
continued text”
Regards.
AW
I believe the wrapping will be done automatically based on the width and hieght properties of the field in the report…
Thanks for help
There is a properties on EDT called ‘DisplayHeight’ there I set up height and choose this extended data type to filed in the report
Regards
The change in the EDT will effect all those place where it has been used, rather change the properties of field in the report…
I,ve created a new EDT only for my needs, so everything should be ok
Kindly Explain Me Hoe you create this new EDT …
thanks in advance
Try changing the Dynamic Hieght property to true.
Saurabh
