I have piece of code: //-Start of code- FileName := ‘C:\Temp\SomeFile.stm’; f.OPEN(FileName); //… f.CLOSE; //-End of code- PROBLEM (i do not seeing it before, i very-very confused): IF FILE CONTAINS ‘0D0A0D0A’ (in hex, ‘double new line’) AS LAST 4 BYTES, THEN Navision HANGS UP AND DO NOT RESPONDS (tested in 2.60D and 3.01 versions of NAV-F/A under Windows2000). After removing last 2 bytes (???) all works fine. WHAT-IS-THIS??? THAT-IS-DIFFERENCE??? Business Applications Programmer Sertified Navision Developer SIA “Sintegra” Latvia
