Hello everybody,
I try to create a xml file with comments and it works fine. Now I try in batch job and the following error appears :
System.InvalidCastException: Unable to cast object of type ‘Dynamics.Ax.Application.XmlComment’ to type ‘Dynamics.Ax.Application.XmlElement’.
At the line :
xmlNode = xmlNodeWrite.appendChild(xmlDoc.createComment(xmlNodeRead.innerText()));
Is there a way to create xml comment in batch job?
Thanks in advance.
Hello Florent,
Did you get an answer to the above question of yours? I faced a similar issue while trying to writeoff customer balance through a batch. Similar to your case the code was working fine manually for me aswell but through a batch I was getting invalidcastexception for LedgerJournalEngine_Daily being type casted to LedgerJournalEngine. I worked around this issue by using an object of LedgerJournalEngine instead of LedgerJournalEngine_Daily. However I would like to know whether AX batch jobs support Type casting or not?.
