Hello
Using AX2012
We have migrated product data and the default setting for the purchase lead time is calendar days
Is there a parameter to switch from calendar days to working days
Have over 100K items to toggle
Hello
Using AX2012
As per my knowledge, we can use the fill utility for updating a this particular field for all the items.
Let me know if this works for you.
I do not see the option for fill utility for that field
There is no parameter - if the fill utility is not available you would need to write an update script.
