Hi guys!
I have a problem about workflow in AX 2009, it doesn’t work and when I checked the Event Viewer, the error message is something like this “.NET business connector fail… etc.”.
Please help me…
AML
Hi guys!
Please help me…
AML
AML,
GO through this site :
HI AML…
ths user shd have full administrator rights, if not also you ll fase this error,
i spend more than week for this error …
Hi Guys,
Good day!
Still doesn’t work for me.
To Vishal Tiwari:
Regarding to the link you’ve posted, what user should I put?
To Arun:
What do you mean? I’m a little bit confuse about this.
Hope to hear from you very soon guys.
AML
This would help you, it helped me heaps before!
Hi Heylin,
Is it ok if I install the Workflow and the business connector at the same time?
AML
I think it be would be better that you don’t install at the same time.
Hi Heylin,
Good day!
Still doesn’t work for me, I don’t know why but I already did all the instructions in the manual you’ve given to me.
Please help me.
Hope to hear from you soon.
Thanks!
AML
hi AML
Very gud morning to u,
u must have proper administrator rights on ur pc,
if u dont have proper administrator rights on ur pc also u ll get these kind of errors
Hi guys,
I encounter an error message after I configure the Workflow Infrastructure.
After I clicked the Finish button I got this error message.
What does this error mean?
Looking forward to hear from you guys.
Thanks!
AML
Hi Arun,
Good day!
I’m a little bit confuse, you mean the User that I used? or the business connector?
AML
hi AML,
Better check for both the user…
Hi Arun,
Sorry for the ignorance, I’m just new to AX. Can you give instructions on how to check it?
AML
Hi Guys,
Good day!
Below is the screenshot of one of the following steps when installing Workflow in AX 2009.
I just want to know if what should I put here, is it the Admin account? or the Business Connector account?
Looking forward to hear from you guys very soon.
AML
hi AML,
install the workflow with administrator rights user id and .Net business connector also shd have administrator rights.
Hi Guys!
We already solve the the Workflow issue and it is running well now. After following all the workflow installation steps, we just deleted all the pending workflow in the workflow history and it works.
Many thanks to all of you guys!
AML
