WorkFlow work item is not created for some workflows.
HI all,
I have in all 21 workflows configured, all are running properly. But sometimes the approval starts and the workflow work item is not created, the workflow gets stuck. I have configures batches properly and they are not going into error, hierarchy of the user is also proper. also the service is not restarting and the workflow IIS is also running properly. I have checked the event log of batch-AOS server as well as IIS server but fount nothing.
The amount approval for workflow is less then 1000 and we have applied the KB2398999 patch.
I am using AX 2009 with sp1. Can anyone please suggest what might cause this problem.
Hi Tejas,
What is the basis of your Workflow system. Can u put some light on that. I also have set up workflow system with FoldewMill and believe me i have never encountered a problem. May be you can think about trying that. Check this link for the solution : http://www.foldermill.com/news/workflow-software
