Workflow through Code
I created workflow for my module.when i press new in the configuration window .the dialog box shows empty.
how can i get the my workflow type to create.
MSDAX
Can please be more specific…
Which version of AX you are using? If AX 2009 check whether you have created workflow templates or not.
Hi Pradeep,
Thanks for given replay.
I developed in AX2012…
MSDAX.
Hi MSDAX,
Please overrride the CanSubmit method in the table or form and write the logic to make it enable and enable the workflow properties on corresponding form design property.
Please go through …
http://learnax.blogspot.in/2012/01/dynamics-ax-2012-workflow-development.html
Hi ,
Thanks Chaitanya and Vishal for given replay.
I successfully developed Workflow for the base modules and it works fine .but coming my developed module all workflow related development is completed when i press new in the workflow configuration window the dialog box shows empty.how can i get query in this window.
which class is executed to get workflow template data from particular module.
Is this solved?
No.
