Workflow stopped after review approval.... Status still "in review"
actually i am not able to find out the issue in workflow for purchase requisition.
when i have done review approval then also status remains same"in review"
but when i am starting the workflow engine from back end then it is working.
please help me for the possible causes ?
Thanks and regards.
thanks and regards
I’m assuming that there may be more then one approvers set up in your workflow. So, once the review is completed, it may have been routed to the next approver(after you run the workflow engine).
what is your workflow history is showing? is it happening same for all the PRs?
Can you run wizard in System administration/Setup/workflow/workflow infrastructure configuration and check.
hi
thanks for ur kind reply !!
its not working for me.
yes its repeating for all PR’s
