workflow permissions
how to assign workflow permissions to user groups? when i try to assign i clicked the permissions button and select the permissions tab and i select the workflow in the viewing drop down list.but in that only no access is editable and remaining are non editable how to assign full control to that user group?
Hi Kishore,
Don’t go through User wise.
Go through User group wise.
Please find the below screen shots.
hi saju,
when i try to give the workflow user group permission noacess is only editable and remaining are non editable .
please help me to solve the solution
Hi Kishore,
Check whether the User you have logged in has Admin Rights,
else
Click on User groups>Select Admin>Select Tab Users> Check whether the User is there in Admin Group,
Here you can assign user the permissions.
Ansar Basha.S
Hi Kishore,
else
Ansar Basha.S
Hi Ansar,
The user have admin rights.
Hello,
I guess you already solve the problem.
Just in case if you haven’t find the solution, to set access right, please expand the node to “workflow element”, then you should able to set access right.
