I don’t see any content in your post, please elaborate your issue.
Don’t forget to tag your AX version.
You don’t have anything to approve or cancel until you submit the document to workflow.
Hi Martin Drab,
Thanks For Quick Response,
I have created workflow from scartch for module HR for newly created employee cinfirmation on HCMWorkerListPage on version 2012 r3 CU10 .
I am able to submit with instruction but its not showing any approve ,reject,cancel to the assigned user.
That is the issue i am facing.
I have checked all classes wich was generated through wizard.
Thank,
Manali
