workflow issue
hi all,
am using Ax 2009 , i have created work flow for leave request approval , but when am trying to make the configuration active it is show me error “” The workflow configuration could not be activated because the configuration is invalid.""
can u help me please
Many Thanks
Hi can you check below points
  1. you made the workflow active
  2. check if all the user in the workflow has permission for the transactions
  3. if all the user id and Employees are linked if you are assignin based on userid
Regards
I doubt that you have not configured the workflow .
Check all these are set properly
Like conditions and submission instructions and under step 1 - work item subject and instructions
Thanks - JK
