Workflow Installation error
I cant install workflow in my server. It shows the below error.
Workflow cannot be installed, because the appliaction pool MicrosoftDynamicsAXWorkflow50 that setup needs to be create and cofigure already exists and cannot be recreated because other virtual directories refernce it. Use IIS managed utility to resolve the conflict.
I tried to delete the MicrosoftDynamicsAXWorkflow50 from IIS manager but it shows below error.
You cannot delete an application pool that contains the applications. You need to reassign all the application in this application pool to some other pool.
I tried to reassign it but it cant be moved.
Please help to slove the issue.
Thanks.
I resolved a long time ago.
As application pool already exist make sure it is not used so simply delete and recreate it.
If it is used and have application running make sure to remove all the dependent and delete the pool and recreate it.
Else create a new application pool and proceed further.
