WorkFlow installation error in Axapta 2009 -Not installed on server
Hi Friends ,
I am facing problem when i am installing Workflow in Axapta 2009.
steps i did:
  1. Installed EnterPrise portal on same server and selected default Website. Now EP is running perfectely.
  2. I have changed Default web site port from 80 to 83 in IIS server.
  3. I have created 2 workflow accounts .I.e WFSYS for work flow system account and WFExe for workFlow Execution Account and Configured in Admin-setup-security-system Account .
  4. .net bussiness connector is installed and working fine.
Now when i am installing Workflow on axapta 2009 i am getting following error log.
Can anyone please tell me what i will do with following error. or some one tell me correct procedure for WorkFlow installation.
=== Setup logging started: 12/21/2010 2:41:41 AM ===
Running file: “C:\DOCUME~1\SKESAR~1\LOCALS~1\Temp\2\AxSetup\AxSetup.exe” RelatedFilesDir="E:"
AxSetup version number: 5.0.593.0
Microsoft Windows NT 5.2.3790 Service Pack 2 (32 bit)
AXAPTA09TS
DEMO\skesarwani
Interactive: True
RelatedFilesDir=E:
Property RelatedFilesDir set to: 'E:'
Property SetupLanguage set to: 'EN’
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-12-21 02-41-41\DynamicsSetupLog.txt
=== Starting evaluation of existing installation state ===
Application Object Server instance 1 has been installed with the name 01-DEMO_AX2009_SP1_AOS_Stadard.
MSI file: Components32.msi Installed: True
MSI file: ClientHelp.msi Installed: True
Property ClientHelpLanguages set to: 'EN-US;EN-GB’
Previously Installed Component: Application Object Server (AOS) (01-DEMO_AX2009_SP1_AOS_Stadard)
Previously Installed Component: Client
Previously Installed Component: Role Centers and Enterprise Portal
Previously Installed Component: .NET Business Connector
Previously Installed Component: Enterprise Portal developer tools
Property RunMode set to: 'AddRemoveFeatures’
=== Checking parameters ===
Property InstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\50’
=== Starting UI phase ===
Property RemoveComponents set to: '0’
Property BypassWarnings set to: '0’
Entering method GetBusinessConnectorProxyAccount
The API return value is demo.local\sKesarwani.
Leaving method GetBusinessConnectorProxyAccount
Entering method IsRunningMode
The API return value is True.
Leaving method IsRunningMode
Entering method GetWorkflowSystemDomainAccount
Retrieving workflow system account.
Leaving method GetWorkflowSystemDomainAccount
The return value from this method is ‘demo.local\WFSys’.
Property InstallWorkflow set to: '1’
Property BusinessConnectorProxyAccount set to: 'DEMO\skesarwani’
Property BusinessConnectorProxyAccountPassword set to: '**********'
Entering method GetIisWebSitesOnTheLocalSystem
Retrieving the list of Web sites on this system
Entering method GetNamesOfAllWebSites
Leaving method GetNamesOfAllWebSites
The return value from this method is ‘1,1121112642,1653210679,2’.
Entering method GetFriendlyNameOfWebSite
The input parameters to this method are: '1’
Entering method GetWebSite
Leaving method GetWebSite
The return value from this method is ‘1’.
Leaving method GetFriendlyNameOfWebSite
The return value from this method is ‘Default Web Site’.
The input parameters to this method are: '1121112642’
The return value from this method is ‘1121112642’.
The return value from this method is ‘SharePoint Central Administration v3’.
The input parameters to this method are: '1653210679’
The return value from this method is ‘1653210679’.
The return value from this method is ‘SharePoint - 80’.
The input parameters to this method are: '2’
The return value from this method is ‘2’.
The return value from this method is ‘Microsoft SharePoint Administration’.
Entering method GetLoggableNamesOfWebSites
The input parameters to this method are: 'Microsoft.Dynamics.Setup.IisWebSite[]:4’
Leaving method GetLoggableNamesOfWebSites
The return value from this method is ‘Default Web Site (1),SharePoint Central Administration v3 (1121112642),SharePoint - 80 (1653210679),Microsoft SharePoint Administration (2)’.
The list of Web sites are ‘Default Web Site (1), SharePoint Central Administration v3 (1121112642), SharePoint - 80 (1653210679), Microsoft SharePoint Administration (2)’.
Leaving method GetIisWebSitesOnTheLocalSystem
Entering method CheckForWorkflowSetupConfigurationNameClashes
The input parameters to this method are: 'Default Web Site’
Checking for availability of names for Workflow setup
Entering method DoesVirtualDirExist
The input parameters to this method are: 'MicrosoftDynamicsAXWorkflow50,1’
Entering method GetVirtualDir
Entering method GetRootVirtualDirMetabasePath
Leaving method GetRootVirtualDirMetabasePath
The return value from this method is ‘IIS://localhost/W3SVC/1/Root’.
Leaving method GetVirtualDir
The return value from this method is ‘null’.
Leaving method DoesVirtualDirExist
The return value from this method is ‘False’.
Checking whether a Workflow virtual directory already exists with this name: The required name is not in use.
Entering method DoesAppPoolExist
The input parameters to this method are: 'MicrosoftDynamicsAXWorkflow50’
Entering method GetAppPool
Leaving method GetAppPool
Leaving method DoesAppPoolExist
Checking whether an application pool already exists with this name: The required name is not in use.
Leaving method CheckForWorkflowSetupConfigurationNameClashes
The return value from this method is ‘None’.
Property WorkflowWebSite set to: 'Default Web Site’
Property WorkflowAosAccounts set to: 'demo.local\nseth’
Property ResetIIS set to: '1’
=== Starting execution phase ===
=== Setting up ASP.NET 2.0 ===
Configuring the .NET Framework ASP.Net for IIS
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -i -enable
Start installing ASP.NET (2.0.50727).
Finished installing ASP.NET (2.0.50727).
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -sn W3SVC
Start registering ASP.NET scriptmap (2.0.50727) at W3SVC.
Finished registering ASP.NET scriptmap (2.0.50727) at W3SVC.
=== Setting up Components ===
Launching MSI: /i “E:\Msi\Components32\Components32.msi” /qb-! /l*v “C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-12-21 02-41-41\Components32 Log.txt” DIRECTEXECUTE=1 SETUPLANGUAGE=EN INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\50” INSTALLDIR32=“C:\Program Files\Microsoft Dynamics AX\50” ADDLOCAL="ClientUI,EnterprisePortal,NetBusinessConnector,EnterprisePortalTools,Workflow,ClientConfig"
Following are messages from the MSI actions log file Microsoft.Dynamics.Setup.Workflow.InstallLog, which could include earlier messages, (check the date):
Uninstalling assembly ‘C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Workflow.dll’.
Affected parameters are:
action = uninstall
rollbackfaileduninstall =
installtype = notransaction
assemblypath = C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Workflow.dll
logfile = C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Workflow.InstallLog
>>Uninstall: Workflow Start 12/21/2010 12:27:37 AM
>>Uninstall: Entering method GetIisWebSitesOnTheLocalSystem
>>Uninstall: Retrieving the list of Web sites on this system
>>Uninstall: Entering method GetNamesOfAllWebSites
>>Uninstall: Leaving method GetNamesOfAllWebSites
>>Uninstall: The return value from this method is ‘1,1121112642,1653210679,2,446484265’.
>>Uninstall: Entering method GetFriendlyNameOfWebSite
>>Uninstall: The input parameters to this method are: '1’
>>Uninstall: Entering method GetWebSite
>>Uninstall: Leaving method GetWebSite
>>Uninstall: The return value from this method is ‘1’.
>>Uninstall: Leaving method GetFriendlyNameOfWebSite
>>Uninstall: The return value from this method is ‘Default Web Site’.
>>Uninstall: The input parameters to this method are: '1121112642’
>>Uninstall: The return value from this method is ‘1121112642’.
>>Uninstall: The return value from this method is ‘SharePoint Central Administration v3’.
>>Uninstall: The input parameters to this method are: '1653210679’
>>Uninstall: The return value from this method is ‘1653210679’.
>>Uninstall: The return value from this method is ‘SharePoint - 80’.
>>Uninstall: The input parameters to this method are: '2’
>>Uninstall: The return value from this method is ‘2’.
>>Uninstall: The return value from this method is ‘Microsoft SharePoint Administration’.
>>Uninstall: The input parameters to this method are: '446484265’
>>Uninstall: The return value from this method is ‘446484265’.
>>Uninstall: The return value from this method is ‘MicrosoftDynamicsAXWorkflow50’.
>>Uninstall: Entering method GetLoggableNamesOfWebSites
>>Uninstall: The input parameters to this method are: 'Microsoft.Dynamics.Setup.IisWebSite[]:5’
>>Uninstall: Leaving method GetLoggableNamesOfWebSites
>>Uninstall: The return value from this method is ‘Default Web Site (1),SharePoint Central Administration v3 (1121112642),SharePoint - 80 (1653210679),Microsoft SharePoint Administration (2),MicrosoftDynamicsAXWorkflow50 (446484265)’.
>>Uninstall: The list of Web sites are ‘Default Web Site (1), SharePoint Central Administration v3 (1121112642), SharePoint - 80 (1653210679), Microsoft SharePoint Administration (2), MicrosoftDynamicsAXWorkflow50 (446484265)’.
>>Uninstall: Leaving method GetIisWebSitesOnTheLocalSystem
>>Uninstall: Entering method Deconfigure
>>Uninstall: The input parameters to this method are: 'MicrosoftDynamicsAXWorkflow50’
>>Uninstall: Reversing the changes made during Workflow setup
>>Uninstall: Entering method DoesVirtualDirExist
>>Uninstall: The input parameters to this method are: 'MicrosoftDynamicsAXWorkflow50,446484265’
>>Uninstall: Entering method GetVirtualDir
>>Uninstall: Entering method GetRootVirtualDirMetabasePath
>>Uninstall: Leaving method GetRootVirtualDirMetabasePath
>>Uninstall: The return value from this method is ‘IIS://localhost/W3SVC/446484265/Root’.
>>Uninstall: Leaving method GetVirtualDir
>>Uninstall: The return value from this method is ‘null’.
>>Uninstall: Leaving method DoesVirtualDirExist
>>Uninstall: The return value from this method is ‘False’.
>>Uninstall: Setup could not detect Workflow virtual directory ‘MicrosoftDynamicsAXWorkflow50’.
>>Uninstall: Entering method DoesAppPoolExist
>>Uninstall: Entering method GetAppPool
>>Uninstall: Leaving method GetAppPool
>>Uninstall: Leaving method DoesAppPoolExist
>>Uninstall: Setup could not detect the Workflow application pool ‘MicrosoftDynamicsAXWorkflow50’.
>>Uninstall: Leaving method Deconfigure
>>Uninstall: The return value from this method is ‘None’.
>>Uninstall: Workflow End 12/21/2010 12:27:37 AM
Starting configuration of Workflow
Entering method SetBCProxyAccountInAxapta
The API input parameter is DEMO\skesarwani.
Entering method UpdateBusinessConnectorProxyAccount
An error has occured while Setup was establishing a connection through Business Connector. Error: Dynamics Adapter CallStaticClassMethod failed.
Leaving method UpdateBusinessConnectorProxyAccount
An error occurred during setup of Workflow.
Reason: An error has occured while Setup was establishing a connection through Business Connector. Error: Dynamics Adapter CallStaticClassMethod failed.
Workflow was left in a partially installed state. Review the log messages to determine whether you can manually finish the installation. If not, then you need to: 1) Rerun Setup and choose the option to remove Workflow. 2) Correct the system problem that caused the error. 3) Rerun Setup and install Workflow again.
=== Rolling back setup of Workflow due to error ===
Launching MSI: /i “E:\Msi\Components32\Components32.msi” /qb-! /l*v “C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-12-21 02-41-41\Components32 Rollback Log.txt” DIRECTEXECUTE=1 SETUPLANGUAGE=EN INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\50” INSTALLDIR32=“C:\Program Files\Microsoft Dynamics AX\50” ADDLOCAL=“ClientUI,EnterprisePortal,NetBusinessConnector,EnterprisePortalTools,Workflow,ClientConfig” REMOVE="Workflow"
Rollback of === Rolling back setup of Workflow due to error ===
installation has been completed. For details about why the installation failed, see the previous messages in the log.
=== Setup was canceled or failed. For details see the previous messages in the log.
=== Setup logging ended: 12/21/2010 2:52:25 AM ErrorLevel/ExitCode: ‘1’ ===
Please give me solution as soon as possible. Because I want do some development work on workFlow environment.
Regards
Sachin
