I dont know about the NAV 4.o workflow but I need to configure the work flow for purchase order.
My scenario :
There is different branches in the company. Each branch having one head if a person sends a approval request then it will go to corresponding head.So I need to configure like that
Please do let me know if anybody having the solution
Thanks in Advance
A.Loganathan
You should set it in Approval user setup…
Thanks mohana
I seen work flow template in administrator menu. I need more clarification to set up.
can u help me to set up the work flow.
Thanks in Advance
A.Loganathah
You should setup that in Approval User Setup…
like
User A and B belongs to one unit (Approver is Z)
and User C belongs to another Unit (Approver is Y)
then
Set like
Userid A - Apprpver ID Z
Userid B - Apprpver ID Z
Userid C - Apprpver ID Y
Mohana I can’t find the approval set up in NAV 4.0 SP3. please tell me where is it.
Is it possible to use work flow template ? But it have only the following fields
Task/Authorization
Min Value
Max Value
User Id
Response time
I CANT ATTACH THE SCREEN
PLS TELL ME THE SOLUTION
THANKS
DRB
July 8, 2011, 9:20am
#6
I think Approval functionality was introduced in navision 5, and prior versions don’t have it.
Check in your database if you have Approval Setup (Form No. 656)
Object Designer >> Forms>> 656 (Approval Setup )
Thanks mohana
There is no Approval Setup form in NAV 4.o SP3.
I think we need to use the workflow template.
Pls help me to get the solution.
A.Loganathan
