Dear All,
I need to configure a basic Workflow in AX 2009…How will I achieve the same…
Step wise solution will be of great help…
Thanks in Advance…
Dear All,
Thanks in Advance…
If you go any module , u can see workflow configuration for that module , Ax provides standard templates, select a template assign the user sand other deatils based on configuration workflow is enables.
Please note there are pre configuration to sue Workflow setup in administration module and basic.
Regards
Thanks Sudhakar,
I am configuring Purchase Requsition Workflow…If i arrive with any hick-ups will post the same…
Thanks…
