Hi Guys,
Please tell me adding a new node to Start from in Hierarchy workflow for AX 2012.
Thanks in advance.
Hi Guys,
Thanks in advance.
To start with Ax 2012 workflow, start with creating workflow category and workflow type.
Abhishek
Hi Abhishek Soni**,**
Thanks for your replay, it is not for new module.
I need in workflow configuration -->Assignment —>Hierarchy -----> Hierarchy Selection → Start form.
standard system have workflow originator and workflow worker in this node i need new lookup…like., worker
Viajy,
You have to create a new field in the table that your workflow is working , this field must have relation with Empltable (Employe table), in my case i duplicated the Requisitioner field (on Purchreqtable) and set a new Name and label.
After this you have to create a new Workflow template for the Form that you using, i suggest that you use Workflow Wizard, it work very fine.
I hope that i help you
Sorry for my bad english
Were you able to add your node to the start from? I need to add the worker node to the Travel Expense Workflow and can’t figure out how. If you were able to solve yours. Could you please share how?
