Workflow Error
Hi
I have configured Workflow Properly & attached batch Job in rhe workflow.
But workflow is not moving for approval after submition.When i go to Workflow history it exist in Pending workflow.
But workflow status is not gettnig change from “Submitted”.
I run the batch job also.After that i run the Workflow tutorial Form from AOT.
It through some Class Error.Says
SysworkflowEventDispatcher - OnAcknowledgeWorkItem
SysworkflowEventDispatcher RaiseWorkItemAcknowledgementEvent
ClrObject Static method Invocation Error.
Exception has been Thrown by the target of an invocation.
I compiled & forward these Classes.
But even after that Workflow is not Moving .
PFA for Error.
Help me out in this.
Neeraj Gupta
Hi neeraj,
Over the here, the scenario is that work flow is not getting triggered right??
I would appreciate if you would re configure the bacth for workflow thru workflow configuration wizard
Try this link :http://workflowax.wordpress.com/category/dynamics-ax-2009/page/1/… keep incrementing pages
and let me know.
