Workflow Error in ax 2012
Hello Friends,
I have created a Purchase Order workflow, When i can activate the Workflow i got an below error:
"The workflow configuration could not be activated because the configuration is invalid."
Please help me…
Chetan
Hi Chetan,
Please delete the workflow and recreate the same.
It may resolve the issue.
Chetan, the workflow you created might be still having some errors which need to be resolved to activate the workflow. you might haven’t noticed it. Go to workflow designing form, you will see the errors.
Hello,
Now it is working
Actually the error is regarding language setup in workflow.
Chetan
