Hi Everyone,
I am trying to create a workflow for Planned Order Details in Master Planning Module in AX 2009.
But what i observed is, in the Form ReqTransPo> Datasources > ReqTrans , there is a
JoinSource as ReqPO and LinkType as InnerJoin.
I had created a workflow for ReqPo datasource, but in the Main method the record is not selecting , i am passing the below code.
public static void main(Args args)
TC_MasterPlanningWorkflow MasterPlanningWorkflow;
ReqPo reqPo;
ReqTrans reqTrans;
reqpo = args.record();
MasterPlanningWorkflow = TC_MasterPlanningWorkflow::construct();
if (args.menuItemName() == menuitemactionstr(TC_MasterPlanSubmitToWorkflow) ||
args.menuItemName() == menuitemactionstr(TC_MasterPlanResubmitToWorkflow))
MasterPlanningWorkflow.init(args.record(), args.menuItemName(), args.caller().getActiveWorkflowConfiguration(), args.caller().getActiveWorkflowWorkItem(), null);
else
MasterPlanningWorkflow.init(args.record(), args.menuItemName(), null, null, args.caller());
if (MasterPlanningWorkflow.dialogOk())
if (MasterPlanningWorkflow.parmSubmit())
MasterPlanningWorkflow.submit();
else
MasterPlanningWorkflow.reSubmit();
args.caller().updateWorkflowControls();
May i know where i had done the mistakeā¦
Thanks in advanceā¦
