Workflow bar not appearing
Hello all,
I assume I am an idiot, but I am wasting time figuring out why.
The yellow workflow bar will not appear for a workflow I have just developed.
The canSubmitToWorkflow() returns true. The form is workflow enabled, with the correct datsource. The submit class has a action menu item, which is set on the template. The showSubmit() on the form returns correctly and sets the “messageDisplayed” to true.
Am I missing something I should check here? It is on the SalesTable form, if that changes anything.
Thanks.
And I did forget one key thing… refresh the AOD, restart the client.
return this.facePalm();
