Hi Masters,
I am working on crouns databse of Indian localization sp1.
I am trying to assign workflow authorization. I donw some setups like below.
I created two users one with Super and MGR.
I assigned work flow authorization for MGR like below.
NAVIGATION: FINANCIAL MANAGEMENTWORKFLOWSETUPUSER SETUP • Click the User-id field and select the user-id MGR you created above. Give an email id in the e-mail field.
WORKFLOWSETUP - WORKFLOW TEMPLATE Selected the following entries in workflow template header:
Transaction Type: Purchase ,Document Type: order
Select the following workflow template lines:
Activity: Authorization
Task/Authorization Level: Enter 1 here.
Min. Value: Enter 1000 here.
Max. Value: Enter 100000 here.
User ID: Select MGR here from the look up
Response Time in Minutes: Enter 30 in this field and close this
Now I created a purchase order with super user id. Now I send to authorization , then the system is asking “Do u want to send for authorization.” I click Yes.
Now I opened with MGR user id . But I am not getting any message.
What is the problem . How to solve this issue.
Thanks and regards
