How can I get the username back on a system with windows login. The table “windows login” has only the SID number as a primary key. So if somone can tell me how I get the SID number back, I could go over the “windows login” table to get the username back. To search sequentiel is not possible, because there are to many records in this table.
Hi Mark,
You can set a filter on the window login table in the ID field and get the name that way. The userid is part of the ID field - look at codeunit 418 Login Management for more details.
Hope this helps
