Using Windows 2000 DNS Server for the network, and Navision Financials 2.6 in 4 different ports in the same server. About 80 clients, and don’t want to modify each HOSTS and SERVICES file. [:D] Does anyone knows how to configure DNS to use Service Location (SRV) type records to connect to the different servers? Thanks a lot. Mauro Gasparri Turismo Pecom S.A.C.F.I. Buenos Aires, Argentina
You don’t need to modify each workstation’s HOSTS/SERVICES files. Using the Open Database dialog in Navision, it is possible to specify Server Name as servername.domain.xx:port and Navision will work fine.
