Hi,explain that why we can’t access action classes?
Not sure what you mean by ‘action classes’. Can you clarify please?
In MenuItems Display,Output, Action objects are there.
In Actions Classes are there.We can’t modify These classes ,why?Explain in detail ?
Generally you should be able to modify the classes. Look for the class under AOT > Classes node, put a break point in ‘main’ method and try.
Do you have any action menu item you are having trouble with?
