why number sequence is increasing by2
Hi friends,
i have created a number sequence with format abc/0000/xxxx . But is is increasing by 2.
for ex: if the line has number sequence abc/0000/0054 , when i create new line it genrate abc/0000/0056
pls help
thanks Manish
Hi, Are you generating no sequence through x++ code? I believe you are doing so and you might call this code twice. Regards, Kuppusamy S
Hi Arun,
Pleae check the general fast tap of number sequence u called .
Might be u entered number “2” on the next .
