I’ve created a report and found some code to add a selectable drop down to the dialog. This part works perfectly. The only strange part is that it sorts it very strange. I’m choosing a Transfer Order and then selecting some or all of the lines from it. If I have an order with 9 or more lines and choose them all, it sorts them like this
1;9;2;3;4;5;6;7;8;10;11;12…etc
If I have an order with 8 lines or less, it sorts them in order. I cannot figure out why.
Here is the code in my UIBuilder
select inventTransferLine
order by inventTransferLine.LineNum
where inventTransferLine.TransferId == orderNum;
if(inventTransferLine)
DS = query.addDataSource(tableNum(InventTransferLine));
qbr = DS.addRange(fieldNum(InventTransferLine, TransferId));
qbr.value(orderNum);
DS.fields().addField(fieldNum(InventTransferLine, LineNum));
DS.fields().addField(fieldNum(InventTransferLine, ItemId));
DS.addOrderByField(fieldNum(InventTransferLine, LineNum));
selectedLines = [tableNum(InventTransferLine), fieldNum(InventTransferLine, LineNum)];
SysLookupMultiSelectCtrl::constructWithQuery(this.dialog().dialogForm().formRun(), dialogLines.control(), query, false, selectedLines);
Can someone see in the code if I’m doing something wrong?
