why filter by field is not working for ReqAttention in PurchTable ?
In purchTable form in General tab i added the field “ReqAttention”.
When i did filter by field work got error as follows
Cannot select a record in Purchase orders (PurchTable). Purchase order: , .
The SQL database has issued an error.
Close the whole application and restart or else just synchronize the associated tables.
Only synchronization didn’t help me.
Found that it was happening because of EDT size 2000 so i changed the EDT size to 1999 and the problem got solved.
Hi Vishal,
Thank you for your reply.The said issue got solved by modifying the stringsize.
Could you please tell me what is the maximum stringsize of string type EDT we can give ?
you can assign string size to (Memo).
To do that, just click the bubble on side of a stringsize property…
hi Satya
I am facing similar error how to find that edt name please help me.
Thanks in advance.
Please help me i am facing this error.
project module---->>Common forms------>>Project details form--------->>Item task button ------>> click purchase order
I got this error
Cannot select a record in Purchase order (PurchTable). Purchase order: , . The SQL database has issued an error.
thanks in advance
