One company data(records) didn’t showed in another company’s data
But same reports are working with another company
yes data will be company specific or it can be shared using virtual company ,
report is something which is showing the data so you can access reports from all company but data will be company wise in that report
if you are trying to ask that in tables data is comapny wise but in report you can see all company data then there will be chance that query which is being used to build report is crosscompany enabled
Thanks Kunal
Here i created a new product named Test123
Company1/Product information management/Common/Products/All products and product masters
when i enter into another company
Company2/Product information management/Common/Products/All products and product masters
here it showing the product named Test123
In this same company
Company2/Product information management/Common/Released products
here it’s not showing the product named Test123
Here how we say data are company specified?
Not all the data is company specific. Some of the entities are shared. Example - Product.
Product is global, you can release it to a specific company. When it is released to company, it will create a record in InventTable. So that you can perform any transactions related to that item in that company.
The table property “Save data per company”, decides whether it is a company specific or global.
You dont, released products are company specific, products are instance specific. You use the functionality to release the product into legal entities. Most businesses with multiple legal entities would not want the majority of information “shared”. Customers and Vendors are common requests, but MDM services that need.
Hi Jeeva ,
I’m not sure with this.
I think the the product not yet released.Check whether it is released or not.
Thank you kranthi, i found it thanks a lot…
