I have a script for renaming column in database written in X++.
public static server void renameColumn()
str sql;
Connection oConnection;
Statement oStatement;
ResultSet resSet;
SqlStatementExecutePermission perm;
sql = strFmt( ‘use DBNAME; exec sp_rename ‘DBNAME.dbo.Table1.Name2’, ‘Name1’, ‘COLUMN’’);
oConnection = new Connection();
oStatement = oConnection.createStatement();
perm = new SqlStatementExecutePermission(sql);
perm.assert();
oStatement.executeUpdate(sql);
Which change existing column named Name2 to Name1.
The strange errors start to occures few minutes later after I call it (using job).
Cannot select a record in Current AOS instances (SysServerSessions). ServerId: 0.
The SQL database has issued an error.
SQL error description: [Microsoft][SQL Server Native Client 10.0][SQL Server]Invalid object name ‘SYSSERVERSESSIONS’.
SQL statement: SELECT T1.SERVERID,T1.AOSID,T1.INSTANCE_NAME,T1.VERSION,T1.LOGINDATETIME,T1.LOGINDATETIMETZID,T1.STATUS,T1.LOADBALANCE,T1.WORKLOAD,T1.LASTUPDATEDATETIME,T1.LASTUPDATEDATETIMETZID,T1.AOSACCOUNT,T1.RECVERSION,T1.RECID,T2.SESSIONID,T2.SERVERID,T2.VERSION,T2.LOGINDATETIME,T2.LOGINDATETIMETZID,T2.STATUS,T2.USERID,T2.SID,T2.USERLANGUAGE,T2.HELPLANGUAGE,T2.CLIENTTYPE,T2.SESSIONTYPE,T2.CLIENTCOMPUTER,T2.DATAPARTITION,T2.RECVERSION,T2.RECID FROM SYSSERVERSESSIONS T1 CROSS JOIN SYSCLIENTSESSIONS T2 WHERE ((T2.SERVERID=T1.SERVERID) AND (T2.SESSIONID=?))
Cannot select a record in Alerts - event inbox (EventInbox).
SQL error description: [Microsoft][SQL Server Native Client 10.0][SQL Server]Invalid object name ‘EVENTINBOX’.
SQL statement: SELECT COUNT(T1.RECID) FROM EVENTINBOX T1 WHERE ((PARTITION=?) AND ((((ISREAD=?) AND (USERID=?)) AND (DELETED=?)) AND (VISIBLE=?)))
Anyone have an idea how to repair it and what exactly cause it?
