Hi All ,
As you know that in the Ax many financial journals would be created and not posted by different users.
Is there any report is available with the user ID says that these journals created by the some X user ?
Thanks in advance.
Hi All ,
Thanks in advance.
You would need to configure the database log.
Turn on the property “created By” in table . This would track the user ids when a record is created.
Just test it by adding that field in Auto Report.
There is report in GL → Reports → Journals → General journal entries that have not been posted.
Filter that report on createdBy field in LedgerJournalTable
You can use audit trail report in GL module.
Pranav…
