Whiling Compiling suddenly dialogbox is appearing as server is unavailable.check your configuration and network settings
Need ur help…Plz help me out…
Due to some reasons Our AX crashed and we uninstalled the ax n DB and re-install it again…After importing the backup(Our Model) and tried to compile and synchornize the DB it…suddenly dialogbox is appearing as server is unavailable.check your configuration and network settings…Plz Help me out…
It sounds like that the AOS crashes. Is it so? What do you see in event log (especially on the machine with AOS)?
Dear Martin,
Thx for the reply.
Yes wen AOS crashed we got an error that below you can see…
AX32SERV!SQLCONNECTODBC::SQLRETVAL+1CIn Ax32Serv__PID__2876__Date__10_18_2013__Time_01_21_09PM__554__First chance exception 0XC00000FD.dmp the assembly instruction at Ax32Serv!SqlConnectOdbc::sqlretval+1c in C:\Program Files\Microsoft Dynamics AX\60\Server\DevelopmentAX\bin\Ax32Serv.exe from Microsoft Corporation has caused a stack overflow exception (0xC00000FD) when trying to write to memory location 0x1b075cc0 on thread 4
Actually that message is from the crash dumps from AOS server…Event log does not give any proper error message…I used DebugDiag and analyzed the crash…
Did it worked before importing your model? Maybe you didn’t initialize the DB correctly.
