while posting sales order error occured The No.Series does not exist.Identification fields and values:code=''
Dear Sir/Mam,
while posting sales order error occured The No.Series does not exist.Identification fields and values:code=’'
herewith attached screenshot please find, please give me solution asap
Sandeep.
What did you try to solve the issue?
Don’t use words like ASAP in forums.
Sorry Sir
i checked the no. series and posting no.series on sales order
Check whether you have a value in No. Series field of Sales Order for which you are getting error
I Check No. Series field of Sales Order. the field is present there also i check in every sales order i get same error
Sandeep.
Not field. value in the field.
and check whether the value is existing in No. series table
Sir Value also existing in No.series.
Did you try to debug the issue to know where you are getting error?
while debugging it found error in noseriesmanagement
attached screenshot
Have you check No series available in No Series Table ?
i Checked it sir, available in both 308 & 309 table
Problem Resolved after Assigning Excise no. series,
Thanks All
