While applying misc charges after posting purchase invoice. Dynamics AX 4.0 Error : Error message when you run a query that contains three "exist joins" objects in a job in Microsoft Dynamics AX 4.0: "The total, internal size of the records
Error message when you run a query that contains three “exist joins” objects in a job in Microsoft Dynamics AX 4.0: “The total, internal size of the records in your joined SELECT statement is [Number1] bytes”
I searched on microsoft knowledge base but its asking for hotfix to contact to microsoft and they may charge for support.
Is any solution for usch errors?
Your prompt support will be highly appreciable.
