Hello, Microsoft Business Solution Partner Certification requires that atleast one employee has MS SQL certification. The requirements then go on to stipulate that any one of the following four are acceptable. Administering a MS SQL Server 2000 Database Programming a MS SQL Server 2000 Database System Administration for MS SQL Server 7.0 Implementing a Database on MS SQL Server 7.0 Which is the most useful on its own? Are any tough without the other? Which is the easiest[:D]!? Thanks for any opinions!
Hi! As far as I know, MS is retiring SQL Server 7.0 exams on December 31, 2003. Therefore, it woudn’t help much to prepare for those exams [;)] Jurica
