is there any way to add a empid(by field), name(by method) in a form’s init() method???
i tried using [tablenum(tablename, field1), tablemethodstr(tablename, methodname)], but i am getting an error… how to solve this? i need to get the display method name next to the emplid???
One easy way is to create a display method in the table which you are currently using… Then , create one string field in your form design, select the datasource and in Datamethod, type the created method name…Thats it… There is no need add code in form init method…
