which dimensions should select
Client has two Locations A , B.
Global Dimensions are Unit and Cost centre .
Unit Dimension Values - A, B
Cost Centre Values - Electrical , Machanical
Now when user transfer the material from A location to B .
which dimension values should user select ?
It does not work like that. Dimensions cannot represent locations because you cannot alter them mid-way through a transfer order. At least that is how I remember it, a limitation of the system due to the nature of the transaction.
