Which code is Execute when I click OK & New on a card page
I have written a code on OnQueryClosePage trigger it works. But the problem is when I click OK & New button that time OnQueryClosePage trigger not executed.
Please suggest your opinion which trigger gets execute when users clicks OK & New button instead of New button.
Hello,
try putting the code also in the OnNewRecord, OnFindRecord and OnNextRecord.
best regards,
Thanks thomos,
I tried but OnNewRecord and OnNextRecord those triggers are executed but I trying to check some mandatory fields on close page.
Thanks & regards,
Pravin Deore.
Ok, do this.
Create a variable for the form and in the record type select form/page, in the form/page create a function Set parameter to the variable record, whichever record you are referring to and the code will be like below
Variable Data type Value
ChangeStatusForm Form/Page Production Order
In Changestatusform new function
Set(ProdOrder);
ChangeStatusForm.Set(Prodorder);
IF ChangeStatusForm.RUNMODAL() = ACTION::Yes THEN BEGIN
(Your Code)
end;
Thanks sbhatbng,
I have written code on default customer card.
Thanks & regards,
