version : ax 2012
Table Name : GeneralJournalAccountEntry and GeneralJournalEntry
When was the record insert thoseTables…,
where is the insert method for these two tables
version : ax 2012
Add a break point to the insert method and see the call stack.
I don’t know where is the insert method
You may not be having insert methods on those tables, Just override them and add a break point and run the process (example - posting of general journal)
I can see that insert happens from here,
\Classes\LedgerPostingGeneralJournalController\transferLines
\Classes\LedgerPostingGeneralJournalController\transferEntries
