hi
Where does the AOT lie in the database
thanks ®ards
hi
thanks ®ards
The AOT is not stored in the database.
It is stored in *.aod (Axapta Object Data) files in the Application\Standard folder of your AX installation.
The closest you can go in the DB is the UtilElements table,
There is also a form displaying the contents of this table . it is located under DevTools\Application Objects\Application Objects
Good luck
