Where can i find the Class
Hai to all,
i need to work on the **FormComboBoxControl class .**But i didn’t get that Class in my AOT classes.
am working on VPC .
This is a global kernel class… forget about that :slight_smile:
Also, EVEN IF YOU COULD, you better don’t do any work on such level classes, UNLESS you have thought all over your solution as any modification at such general application level may affect the whole system, every form, evey dialog button etc…
You can take a look at this class in AOT → System Documentation → Classes → FormComboBoxControl
P.S. There might be situations when you see some execution code in debugger’s stack trace from “this class”, however this isn’t the actual executable code in that SYS level class.
