It’s not an error. It just says that there is nothing to show in this report.
how to solve this one?
i even checked the security roles, everything is fine
You need to create data matching the report query.
Since you kept it in Developer forum i suppose you already consulted your functionals on this. Answer my below query, Mostly you will get solutio in it…
Did you customized this report or using standard one?
Did your functional checked setups for work templates and wave templates. Check if your Work is have enough line for picking and Packing with required storage locations?
If all above point is okay,then please ask expected output to him and try to debug report from your end first…
Always consider above things as prerequisite/ thumb rule for any investigation since you are beginner.
5.All Microsoft warnings/errors/Infolog are self explanatory which will always give you direction for fixing bug…
Post your answer of above questions here and if you already get solution which getting answer of above questions make sure to mark it as helpful…
