When customer balance change
I have to export customer balances on a daily basis, but only the customers with a changed balance since the last export. I tried the trigger ONINSERT in the Cust Ledger Entry, but for some reason, the trigger wont fire.
Can anyone guide me in the right direction here :slight_smile:
It’s on a NAV 2009 R2
Regards
Jens
Hello,
Create a new field in Customer Card. BalanceField.
Everytime the report runs compare Balance with BalanceField. If different insert new Balance and Output the report.
It’s easier. . .
The changes in Cust Ledger Entry are controlled by a codeunit which is placed in the on modifiy trigger of the table.
best regards,
Hi Thomas,
Thank you for your reply. I’m almost there :slight_smile:
I have created a field on the Customer table called: BalanceField
Thing is, i have to do this from a code unit, and i have made the following
Customer.SETFILTER(Customer.Balance, ‘<>%1’,Customer.BalanceField);
IF Customer.FINDSET(TRUE, FALSE) THEN
BEGIN
REPEAT
// Do some export stuff here
Customer.CALCFIELDS(Balance);
Customer.BalanceField := Customer.Balance;
Customer.MODIFY;
UNTIL Customer.NEXT = 0;
END;
Seems like i’m having issues with the SETFILTER command. Cause it always find customers with a balance, and not where it differs from the balancefield.
Best regards
Jens
Hello,
Have you done the CALCFIELDS before?
BEGIN
REPEAT
Customer.MODIFY;
END;
best regards,
Sorry, forgot to mention. This type won’t work. You have to loop thru it to get it working.
It’s not clear what the Customer.BalanceField is in this code. Loop thru records and at the end of every loop do a Customer.RESET.
best regards,
Hi Thomas,
Thanks, that helped a lot. :slight_smile:
I now search through all customers, testing if the balance has changed.
Best regards
Jens
