What is this means
I saw a coding but not used that particular symbol.
AccountingPeriod2 := Rec;
IF AccountingPeriod2.FIND(’>’) THEN
AccountingPeriod2.TESTFIELD(“Date Locked”,FALSE);
UpdateAvgItems(4);
I got the meaning of those lines but what is that find(’>’) what it means.
Cheers.
As it says in the NAV help file:
  • = to search for a record that equals the key values (default)
  • to search for a record that is larger than the key values
  • < to search for a record that is less than the key values
    • to search for the last record in the table (+ can only be used alone)
    • to search for the first record in the table (- can only be used alone)
