what is the difference between runbase and runbaseframework ?
what is the difference between runbase and runbaseframework ?can any body help plz
Runbase : its a class used for tasks that shouldn’t be bachable…
RunbaseBatch :It is used to give the application user option …to shedule a batch job for the task
Hello Vinay,
RunBase class: The RunBase class is a framework for classes that need a dialog for user interaction and that need the dialog values to be saved per user. The RunBase application framework runs or batches an operation. An operation is a unit of work, such as the posting of a sales order or calculation of a master schedule.The RunBase framework uses the Dialog framework to prompt a user for data input. It uses the SysLastValue framework to persist usage data and the Operation Progress framework to show operation progress.
class RunBase extends Object implements SysSaveable, SysRunable
RunBaseBatch class: All jobs that must be able to run in a batch must inherit from this class. The RunBaseBatch framework extends the RunBase framework, and X++ classes that extend this framework can have their operations enlisted in the batch queue.
class RunBaseBatch extends RunBase implements Batchable
RunBaseReport class: The RunBaseReport class makes all reports batchable and creates a standard dialog box.
class RunBaseReport extends RunBaseBatch
This class is instantiated through the SysReportRun Class. It should be used by all reports. The purpose of the class is to:
  • Make all reports batchable
  • Create a standard dialog
If you are creating more complex reports, it might be necessary to inherit from this class. If this is the case, you must create the following methods:
lastValueElementName(). Returns the report name.
description(). Static.
main(). Static.
Note : The corresponding menu item must use the class rather than the report. If you can avoid it, do not create a class and inherit from this class. Try to solve the report in the actual report.
