What is a Macro?
I would like to know what is the use of Macros in Dynamics Ax 2009. Why we need to define it and how?
Thanks & Regards,
Raaj
Hi Naveen,
Macros are pre defined compilers. We can use these macros in X++ code instead of hardcoding the values.
We can create macros in 3 ways. follow the below more info…
http://axwonders.blogspot.in/2011/06/macros-in-ax-2009-ax-2009.html
Sandeep
Hi Naveen,
Macros are pre defined compilers. We can use these macros in X++ code instead hardcoding the values.
Sandeep
Thank you Sandeep for your answer.
