F12 function we are using to open object definition.
I am looking for the code to perform this task.
I need to write a x++ editor script open the object in a new window. Actually we are performing this with the help of F12 but this is not working for all cases.
For example, in x++ code like this
new MenuFunction(menuitemdisplaystr(AbatementCertificate_IN), MenuItemType::Display).run();
when we click F12 on “AbatementCertificate_IN” it should open display menu item since it is using as display menu item in the above code but here it is opening the class existing with the same name.
So I am looking for F12 function code to extend this functionality to open the object in all case through editor script.
Appreciate your reply.
Satish
