Ken anybody explain me what dose mean “::” in navision 5?
Hi Babak,
This operation is used to select an option value using the string label
e.g.
Type on sales line (Table 37) - the option string is " ,G/L Account,Item,Resource,Fixed Asset,Charge (Item)" and this is stored as an integer so type “Item” is stored as 2 (starts at zero)
i.e.
0 - ’ ’ (blank)
1 - G/L Account
2 - Item
etc
So in Nav you could program (please don’t [;)])
if type = 2 then …
but if the option string changes the the code is incorrect so best practice is to use
if type = type::“Item” then…
and the software knows to lookup Item in the option string and return 2.
Look up option strings in the help
Hope this helps
Thank’s so much for help.
