I have duplicated the query “AxdItem” and renamed this to lets say “AxdItemAAA”. I have customized this new query “AxdItemAAA” based on my requirement.
I have created the new AIF Service using this query “AxdItemAAA” through AIF Document Wizard. The Private project got created for my new AIF Service.
It is working fine on my system as per the requirement.
Now my question is how can I move this new Custom Service from my Dev Environment to the UAT Environment?
To be precise, what are the steps that we need to follow to move this new AIF Service from my Dev Environment to the UAT Environment.
Do the same thing as in the development environment. If you created and deployed a service group, deploy the service group in UAT. If you created and activated an extended inbound port in Dev, create or import and active the inbound port in UAT.
Once I have created a new AIF Service using Wizard, is there a way to delete this new service and all the object that got created for this new service permanently from AX?
