WebShop: Navision Error: Cannot send synchronization message
Setup: Local SQL server DSN created which points to local SQL “Commerce” database MTS installed MQ installed as an “independent client”, MQ installed remotely as a “PEC” Queues created with correct permissions. replicated on remote PEC Remote IIS + commerce server Suggestions? Additional info: A separate test VB app is able to write/read from the message queue without a problem Edited by - SimonW on 9/12/00 8:23:01 PM
Are your servers in different NT domains ? ICM Solutions B.V. ir. D.C. Oerlemans dc.oerlemans@icm-solutions.nl
No - but I was having trouble accessing the PDC - so I think the problem was related to not being able to use the “guest” account
Can you describe your topology ? What do you mean by remote server, etc. ICM Solutions B.V. ir. D.C. Oerlemans dc.oerlemans@icm-solutions.nl
