Web services
Hi experts,
I have problem with web services and I want to ask you question about it.
I need to create web service from page that has Property SourceTableTemporary = true.
But i can’t use that service in Visual studio because I can’t retrieve/modify/insert any data from navision.
Is there any solution how can I handle this?
How is the page filled with data using the Windows Client?
Thanks for the reply
Via Tracking Specification table (T336). The page that I need to publish is Item Tracking Lines Page (6510).
(to avoid problems I tried to use Item tracking List Page -6507(because it is not on a temp source) , instead Item Tracking Lines . But in this case Records are recorded only in reservation entry table, but I them need in tracking specification (T336))
